LT1 and TPI
Old Nov 8, 2000 | 01:24 PM
cobrakiller1989's Avatar
LT1 and TPI
Are LT1 fuel injectors the same as the fuel injectors for TPI?? Will they work on TPI??
I am wondering because i have a magazine that sell 24# LT1 fuel injectors for $200 and i need injectors anyway and i think its a lot cheaper than TPI injectors.(not sure though
One more thing
what size fuel pump would you recommend for a 355 with a little over 350 hp and 24# injectors
thanks in advance
Old Nov 8, 2000 | 02:32 PM
Brett's Avatar
I beleive they will. And for that matter, at that price get Ford SVO 24# injectors. They are rated at 24# as tested with lower line pressure and therefore are capable of about 27# as rated by GM standards if my math is right.
1991 RS LT1
every imaginable bolt-on, ungodly LT1 355, and 12 pounds of intercooled boost on it's way in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, first run 13.056 @ 109.52 stock
"So what DOES the back of a Mustang look like?"
Old Nov 9, 2000 | 06:50 AM
Vader's Avatar
CK,
The injectors are different. The Bosch injectors are a little longer, but I'm not sure if that prevents you from using the LT1 injectors on the TPIs. You'd have to measure. I don't have spares for either of mine, and I never got dimensions when they were out.
You might try calling Rich at Cruzin' Performance. He probably has a sample of each type lying around to measure. I do know that the valve designs changed, but that shouldn't make any difference as far as the fuel delivery goes.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 9, 2000 | 03:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I used 94 24lbs LT1 injectors in my TPI setup, no problems on the fit. But I ran very rich at WOT, and had to switch to 22lbs. Since the SVO injectors are rated at a lower pressure, I would only get them if you really needed the extra fuel, or you can burn custom PROMs to reduce the fuel. Otherwise you're going to run rich all the time.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Sanjay
Aug 12, 2015 03:41 PM
