64cc heads/reflector dish or 72cc heads/flat tops
Old Aug 31, 2003 | 10:37 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
What would be better for a 355? I'm wanting to have about 9.5:1 static compression. Would there be any advantage of one over the other as far as combustion efficiency?
Old Aug 31, 2003 | 11:18 AM
ede's Avatar
ede
dished pistons seem to be more in favor now and deeemd the better design, as long as you can get the compression you want. next engine i build would have small chamber heads and dished pistons.
Old Sep 3, 2003 | 05:04 PM
Drakar's Avatar
what is the advantage of dish pistons over flattop?
Old Sep 3, 2003 | 05:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
64cc/flat tops will make about 9.5:1 CR... thats what I would do.
Old Sep 3, 2003 | 06:30 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Even at standard deck height with a .035 compressed thick head gasket a .03 over flat top with 5cc of valve relief will make 9.9:1.
SG91camaro
Sep 5, 2015 10:27 PM
tgp1990
Sep 4, 2015 06:24 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
