loud whistling near pass side intake after running under load car stalls out??
the car is a 1992 bird with v-6 tbi, idles great all day, put it under a load, and it starts losing all power and whistling on the iontake near the passengers side , and stalls out. Will not re-start easily, and have to slam into drive to get it to go .
after cooldown it starts and idles all day, but under a load whistles and dies after 2 minutes of running,,
Is there a common sensor or vac line in that area that is losing vac?, is this a common bird prob?
Car: 4
Engine: 6
Transmission: 5
The whistling is coming from the EGR valve. Either it is defective (not likely), or the catalytic converter is clogged (more likely) forcing exhaust to find a leak up there somewhere.
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
AAAAAAHHHHHHHHH!,
EXACTLY!. Some problem here.
Thanks for the diagnostics.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
3rdgenparts
Aug 5, 2015 11:57 PM
