Can I plumb my TPI fuel Lines?
Old Nov 9, 2000 | 07:45 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I want to use SS lines and make it look racy. So would I be able to connect the hose to the hard lines running along my fender up to the fuel rails? Thanks also if anybody has any pics of this that would be appreciated.
Old Nov 10, 2000 | 06:51 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, Jegs carrys them. They screw onto the steel lines off the fuel rail and allow you to attach #6 AN fittings for custom fuel lines braided or any thing you'd like.
They are part# 310-74730 and go for $33.99
I bought a set and planned on running braided line from the tank to the fuel rail, untill I checked the price of braided line!
They are still brand new and I will sell them to you for $25 shipped.
John
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 10, 2000 | 01:50 PM
Scott C's Avatar
Just make sure that the SS line can handle 50+psi. Most SS fuel lines are only for carbed cars at about 7psi.
Old Nov 10, 2000 | 04:56 PM
Engine: 4.0L
Every SS braided line in the Jegs and Summit catalog are rated for at least 250psi ans some are 300psi. We are talking about real braided line not the sleeves that you get in a dress-up kit.
86 Camaro Sport
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
