Buick Fan Switch?
Old Sep 2, 2003 | 10:38 PM
Trevor K's Avatar
Buick Fan Switch?
I've done the reading, and I want to purchase a new fan switch.
I have a 87 Z28 with the LG4, non-CC. So I don't need to worry about how low I go since my carb will squirt the same fuel regardless right?
With that in mind, what's the lowest fan switch I can get (And it's turn on/off temp's)? I don't want to spend $50-60 on an adjustable one, I'm hoping for a stock replacement.
Also - if you have the part numbers that would be helpful.
Old Sep 3, 2003 | 04:50 PM
Vader's Avatar
If you anticipate ambient temperatures below 10°C, you might want to keep the coolant temperature above 80°. Much lower than that, and you won't get acceptable fuel evaporation in the intake, and may actually get carburetor icing in humid conditions and colder air. If you only use the car in the summer, and don't need to worry about temperaures below 10°, you can probably go as low as 75° without noticing any problems.
Old Sep 3, 2003 | 11:29 PM
Trevor K's Avatar
I thought pretty much the lowest fan switch I could get is a 160 from Hypertech? Is there a GM one that low?
<And yes, the car is summer only>
Old Sep 4, 2003 | 07:24 PM
Vader's Avatar
Not that I'm aware of, but I don't know everything. I do know that AutoMeter offers a wide range of temperature switches for about $20 each.
FormulasOnly
Sep 10, 2015 09:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
