what do u think my car would run? 1/4 mile
Old Sep 3, 2003 | 06:44 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
i dropped in a gm 350 h.o. crate engine (330 hp 380 tq). stock stall with a 700r4. also with 2.73'2 and an open diferential. 255/60-15 rear tires. 650 holly dp carb preformer intake, 14x3 element. what do u think i would run? thanks
Old Sep 3, 2003 | 08:01 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
without driver error...14's mid
Old Sep 3, 2003 | 08:35 PM
cr125r's Avatar
Car: 1988 trans am
that sucks, what about 3.73 open diff? posi? ill be happy with a 13 second car... whats necessary? thanks
Old Sep 3, 2003 | 08:55 PM
smithtc's Avatar
http://www.73-87.com/chp/gm3508.htm
Old Sep 3, 2003 | 10:02 PM
jimmy_mac's Avatar
with a aftermarket stall high 13s at 98 mph. Stock stall low 14s at near same speed.
I estimate this because a guy at the local track runs a 13.8 at 97 with that exact motor and a TPI and 2.73 gears.
Old Sep 4, 2003 | 04:52 AM
Engine: 406
with that open differential, your 60ft times are gonna suck..although the 2:73's will help you out some..if you swap in 3:73's you for sure will need a posi unit...Your link gives you some great info. Im thinking that motor comes with the72cc heads doesnt it?
Old Sep 4, 2003 | 01:38 PM
jimmy_mac's Avatar
I thought the 330 hp 350 HO was the one with 64cc vortec heads.
Old Sep 4, 2003 | 02:33 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I don't know about the chamber size but it does come with Vortec heads for sure.
Old Sep 4, 2003 | 02:39 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I'd say the best you'd run with stock suspension, those 15" tires, and open diff is mid 14. low 14 if your lucky. Switch to a fatter bigger tire, some suspension upgrades, and a good stall and you could hit 13's. The way you are right now, your gonna light up those tires.
Old Sep 4, 2003 | 05:05 PM
smithtc's Avatar
I apologize... I thought the link I gave was for the 330HP motor. I just realized it isn't the same.
http://www.sdpc2000.com/cart.asp?act...id=120&pid=462
I believe that a 3.23 geared posi would put you in the power band effectively enough to net you some mid 13s.
http://www.prestage.com/Car+Math/ET+...+/default.aspx
Old Sep 4, 2003 | 06:44 PM
Engine: 406
Originally posted by smithtc
I
I would agree.....but 3:42's or 3:73's would be a better choice IMO... Not to mention a little tranny work...
PS...just the opinion of a shade-tree mechanic!
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
kyle5647
Aug 7, 2015 03:08 PM
3rdgenparts
Aug 6, 2015 09:03 AM
