Which adjustment comes first ? IAC, TPS or Timing ?
Old Nov 10, 2000 | 01:32 AM
voltran's Avatar
I'm gonna check and adjust ( if necesarry ) all these this weekend. I was wondering which I should do the first ?
Old Nov 10, 2000 | 03:47 AM
Ski89Z28's Avatar
I would adjust the IAC first then set the TPS voltage.
I did it the opposite way and my car ran like crap! I then rechecked the TPS voltage and it was way off! So by my mistake I would do the IAC FIRST,
Good Luck!
Old Nov 11, 2000 | 04:14 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Right. Any adjustment to the IAC minimum air setting also changes the TPS voltage. So if you raise the minimum air flow by opening the butterflies more with the little torx head screw you will also be increasing the TPS voltage.
Depending on the amount of the minimum air flow adjustment, the TPS voltage may or may not remain within spec.
I always set the timing, then the IAC, then the TPS. But I'm open to suggestions if there's a better way.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
