hmm my motor sounds like a deisel...
Old Sep 5, 2003 | 12:04 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
if i get right up next to the plenum with the motor warm i swear it sounds like a deisel motor running.
and if i rev the motor a teeny bit, i get a clack clack clack, almost like a piston slap but louder, not quite like a rod knock, very odd noise. it may be a spun bearing, and if it is, whats the life expectancy on this thing? it only has 4000 miles, why would bearing have spun already...
Old Sep 5, 2003 | 01:03 AM
darbleinad's Avatar
Car: 84 Trans Am
rod knock and a spun bearing are the same thing
Old Sep 5, 2003 | 05:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Anything's possible. I had a "professional" shop build an engine for my Talon. After 500 miles it spun one of the balancer shaft bearings.
Old Sep 5, 2003 | 07:19 AM
Biochem's Avatar
Car: 2002 SOM z28
Klingaton dude, please don't ever even stand near my car... you are seriously bad luck for engines
Old Sep 5, 2003 | 02:27 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Your best bet to find out what exactly is causing your "knock" is gonna be to teardown the engine. Other than that its kind of a hit-and-miss diagnosis.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Andrew6.688
Dec 13, 2015 10:59 AM
xxx3man`
Sep 23, 2015 10:37 PM
TheExaminer
Aug 19, 2015 10:07 PM
