carb, TPI, or TBI?
Old Sep 5, 2003 | 12:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
carb, TPI, or TBI?
ok since the fire, ive been debating whether or not to go back to a carb setup or not. what the pros and cons of a carb setup, TPI setup, and TBI setup. im not after anything fancy, just enough to get air into a 355 that needs at least 600 cfm...
Old Sep 7, 2003 | 10:40 AM
dennis6's Avatar
Car: 1991 Camaro RS
TBI is worthless, unless its a 4 Barrel TBI unit. Look to pay around $1395.
TPI is worthless stock for a 350. You will need the regular TPI parts and a Holley steatlh ram to fix this. If you have a Holley stealth ram, you won't need the Plenum, intake, runners, or fuel rails. The basic HSR setup is about 500 with fuel rains add this to the cost of the rest of the TPI setup.
Carb is great if you don't care about gas mileage, tuning, or winter driving.
Note, I went carb myself.
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
pimp2303
Jul 27, 2017 02:03 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
