changing thermostat
Old Sep 5, 2003 | 05:20 PM
1989TransAm's Avatar
changing thermostat
do i have to drain the radiator fluid and refill again to change the thermostat? i just had that done last fall, and i really dont want to do it again just to put in a thermostat
Old Sep 5, 2003 | 06:32 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
absolutely not.
Just unhook the one hose that runs into it, you might want to stick some rags by the intake as a little bit of antifreeze will come out and the two bolts and the housing is off.
No need to drain it though
Old Sep 6, 2003 | 09:13 AM
Vader's Avatar
As soon as you remove the upper hose or thermostat housing, you'll lose about a half gallon (oh, I'm sorry - a couple liters) and have it drooling all over your engine. It would be easier, neater, and probably less expensive to place a clean drain pan under the readiator petcôck and drain a gallon or so before starting the project, then pour it back into the radiator and reservoir when you're finished.
Old Sep 6, 2003 | 09:44 AM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
hmm, I just changed my 192 therm to a 180 stant and had no such as but maybe a pepsi can full of antifreeze come out
but if vader says so, I would drain it!
:hail:
Old Sep 6, 2003 | 10:19 AM
Vader's Avatar
What size Pepsi can? I don't know everything, you know. I'm here to learn like the rest of us.
You may not lose a lot. but if the system is filled to the top of the radiator neck, you're going to lose some. If you don't mind woking in stick, slippery antifreeze, that's O.K. Just make sure you clean up all the spillage and get a clean, dry gasket surface before you reassemble.
And don't forget the anti seize compound on the bolts. If you break one off trying to remove the thermostat, you'll know why.
Old Sep 6, 2003 | 04:12 PM
onebinky's Avatar
The first time I did a theomostat, I didn't drain any antifreeze out. When I pulled the gooseneck off I lost enough antifreeze to get the ground pretty wet under the car
I second the notion about the antisieze too, you won't regret it next time you have to get in there
Matt
Spyder_TheGamer
Dec 25, 2015 05:07 PM
hydrolic144
Oct 4, 2015 08:23 PM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
perZ
Aug 15, 2015 01:17 PM
