New MAF- car won`t start. Disconnected starts!
Old Nov 12, 2000 | 08:23 AM
BenIroc's Avatar
The same thing happened with my old MAF it
almost started but stopped inmediatelly,if
I try severall times it can start but will
stall after some time. If I disconnect the
MAF, it starts OK.
I have checked the ignition system, the
fuel system and the oxigene sensor and
didn`t fynd anything wrong.
Does the ECM box in this cars go bad?
I`m out of ideas......
What do you think?
BenIroc
89 camaro
Old Nov 12, 2000 | 08:53 AM
BenIroc's Avatar
One more thing.I don`t get any codes when
the car finally starts with the MAF connected
and it runs good then, until it stalls after some time.
When I disconnect the MAF I get code 33.
Thanks.
BenIroc
Old Nov 12, 2000 | 09:42 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Your old MAF was likely fine. Replace your MAF burnoff and power relays.
Old Nov 12, 2000 | 11:46 AM
BenIroc's Avatar
Do you think the problem is the relays?
consider that I don`t get any code with
the MAF connected
BenIroc
Old Nov 12, 2000 | 06:23 PM
BenIroc's Avatar
Anyone has more answers, please?
BenIroc
89 camaro
Old Nov 12, 2000 | 07:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Assuming the wiring and connectiuon are goo and intact, then I'd suspect you are getting a burnoff signal while the car is running...hence the suggestion made earlier to replace the relay...in fact, pull the burnoff relay and see if she runs okay.
Don't run it often with the burnoff relay out, or premature MAF failure will occur.
Also, if there is an issue with poor contacts in the MAF relay, it could send the wrong signal to the ECM.
Then there's always the possibility you got a bad MAF as well.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
86Base
Aug 8, 2015 01:34 PM
