Headlight won't go up: the junkyard said the motors not broke but the relay is bad???
Old Nov 12, 2000 | 08:02 PM
a1987formula350cu's Avatar
Is this true..or is he wrong. He said that because the headlight pops up a little bit that the motor is good but the relay is bad. What should I do??
1987 Firebird Formula 350[*]Stock except...[*]Cragar Street Stars
My Car Website w/ Pics
fyrebird350@hotmail.com
AIM/AOL: FIREBERD350
<<<<---THIS CAR IS FOR SALE(only 49k)--->>>>
Old Nov 12, 2000 | 08:08 PM
Vader's Avatar
87,
If you disconnect the power connector to the suspect motor (a single wire connector) you should be able to raise the headlight manually by turning the **** at the motor in the indicated direction. If you connect the power connector again, the motor should lower the lamp housing. (Be careful when connecting - the light should lower immediately.)
If the lamp housing lowers properly, the problem is not in the motor gearing. You could still have a problem with the end limit switches in the motor, or a relay.
If the lamp housing doesn't lower properly, the motor gearing may be stripped. There is a nylon worm gear in the housing that has a tendency to wear out.
If neither of those provide results, try tapping on the relay and the motor housing with the lights on.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Derick15
Sep 17, 2016 05:28 PM
Jae992
Aug 27, 2015 09:07 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
