305 TPI HEADS what are the specs?
Old Nov 12, 2000 | 07:25 PM
theformula's Avatar
ANyone know the specs?
intake runner
valve diamter
combustion chamber etc...
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (42psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam (i still have to install it )
Old Nov 12, 2000 | 07:57 PM
Vader's Avatar
TF,
Typical 305 heads are 1.84"/1.50" valves, 58cc chambers, and 145cc intake runner volumes. Depending on your castings, the intake runner sizes can vary significantly.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 12, 2000 | 08:47 PM
theformula's Avatar
Thanks for the quick reply vadar. Heres a question I know you will have the correct answer too.
Is the ZZ9 cam to much for my car and what I have done with it? Can I use it with the stock intake manifold and heads?
Can it actually hurt performance?
Now for the hard question. What head do you recommend that will just bolt on with no modification needed and will work well with the ZZ9 and my 305 with mods listed. No one has been able to answer this.
thanks
'92 Formula
305 TPI
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
