who has ZZ4 engines?
so.. who does? do they perform as well as you anticipated? i currently have a '74 Z28 and am looking at getting a 90-92 RS, but installing a crate motor. i was looking at the ZZ4, but i want to make sure that it will give me what i want(which is to blow the doors off most other cars
) what do you think?
) what do you think? Supreme Member
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
You could always just get the short block, a set of the fast-burn heads, HOT cam, and a nice intake and be pushing around 430 HP! I have a list of the part numbers! Hehehe You would really be blowing some doors off then!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
I'll let you know when I crank mine up......whenever that is. Perhaps in the spring. It's really a modified LO5, but it has the ZZ4 rotating assembly. It should haul a-s-s!
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
yea, that is something else im considering. i looked at the ZZ4, the Fast Burn 385, and the 385 Truck Engine. i like the idea of how the torque looks on the truck motor(lowly 3500rpm). what i dont like is having to rev to 5k to get peak power, so would a ZZ4 short block be the way to go? and add my own heads(AFR in mind right now), cam, intake and so forth?
