Fuel pump makes pumping sound, but no pump.
Old Sep 7, 2003 | 03:36 PM
paul5.0's Avatar
Car: trans am 1991
Is It possible to put an external pump on bypassing the OEM pump so I dont have to remove the tank? My pump sound fine, but doesnt pump. Could it be something else, like a clog? Fuel filter is fine.
Old Sep 7, 2003 | 07:41 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Usually if it spins you should get fuel. Pull the filter loose and flick the key a couple times to see if any gas pours out. If not you may have a damaged pickup tube and an external pump wont help any. But yes an extrenal pump (rotary) with at least 6-12 PSI could be used for a TBI setup.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
