Code 45 (O2 rich) and now car won't start!
Old Nov 11, 2000 | 02:14 PM
Biochem's Avatar
Car: 2002 SOM z28
I installed a new Carter street pump the other day and now the car has a tendency to not want to re-start. And it threw up a code 45 (rich oxygen sensor). I also smell it is running rich. It did this the other day too and wouldn't start until the next day. My pressure gauge is reading 7psi too...
Any ideas what is going on?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 12, 2000 | 07:49 PM
Vader's Avatar
Bio,
What carb are you running? Some carbs won't tolerate over 5 PSI at the inlet needle/seat without the fuel pressure overcoming the valve and flooding the bowl.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 12, 2000 | 08:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, definatly sounds like a flooding problem.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
Old Nov 13, 2000 | 06:41 AM
Biochem's Avatar
Car: 2002 SOM z28
Well, it is/was a computer controlled Q-jet. I say "was" because I pulled off the base and found something stuck in the little hole just below the slot in the primary bore. On the left side, the hole flows air (through hole and slot)... right is clogged (hole only). I also broke off the two little screws that hold the throttle blade on too. I could get a new base and be fine (maybe), or just get a new 750vac DP! Sonsidering I will spray in the future... I think I need the new carb.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
indygene
Sep 26, 2015 11:21 AM
Lmancha96
Sep 25, 2015 08:11 PM
