Best way to clean a set of aluminum heads?
Old Sep 8, 2003 | 03:19 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
What's the best way to clean a set of Edelbrock RPM's. It has heavy carbon build up and sludge. I'd like somthing cheap and fast, possibly a way with the valves in tact.
Old Sep 8, 2003 | 03:26 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Spray carb cleaner.
Old Sep 8, 2003 | 03:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Permatex 4MA Gasket Remover and the quarter car wash.
Be careful, that stuff will eat your skin. Make sure you get all of it off the aluminum when you're finished.
Old Sep 8, 2003 | 08:43 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
If your able to take them apart, go to a sand blaster
Old Sep 8, 2003 | 09:23 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Grease Lightning works awesome
Old Sep 8, 2003 | 10:48 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Grease Lightning? what is that? How about an engine de-greaser, and the coin washer?
Old Sep 9, 2003 | 12:54 AM
Morley's Avatar
Valvoline SynPower, I got it to dissolve combustion carbon on a pair of iron heads with 140,000 miles on them. Awsome stuff.
Old Sep 9, 2003 | 06:18 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
castrol superclean
Old Sep 9, 2003 | 03:29 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Valvoline synpower? isn't that fuel injector cleaner? did you use this with the head still on the car?? Maybe the super clean is the way to go?
Old Sep 10, 2003 | 01:28 AM
Morley's Avatar
No, it is a spray carb/throttlebody cleaner and I used it on the heads after I took them off, just to see how strong it was. I had already seen it dissolve the carbon build up in the IAC passages on my TB and wondered if it would attack the burned on carbon from combustion...dissolved it like it was water based paint.
Old Sep 10, 2003 | 03:29 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
WOW! that's a bold statement.
Old Sep 11, 2003 | 01:12 AM
Morley's Avatar
But the truth none the less. Now I have flash rust in all of the combustion chambers, it stripped them that clean.
Old Sep 11, 2003 | 03:00 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
The best way of cleaning them heads is to give then to me.
But anyway a machine shop would only charge maby $40 to do it.
Old Sep 11, 2003 | 03:08 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Dawn takes grease out of your way. That and the brush at the carwash.
Then use some carb cleaner.
Old Sep 11, 2003 | 03:14 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
And the winner is synpower! ding, ding,ding.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
TheExaminer
Aug 26, 2015 04:59 PM
Navy8125
Aug 22, 2015 07:13 PM
