No problem with Firebird this time, but with Cadillac
Old Nov 13, 2000 | 07:51 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
Does anybody know how to get the code for the 88 cadillacs? Do you just cross two terminals like with the Firebirds and then look up the flashes to see what it means or is it more complicated? I also was wondering if anyone has ever taken a EGR valve apart and weakened the spring to compensate for less back pressure on a modified exhaust system. I'd like to do that but don't want check engine flashing at me for that!
'89 Formula 383 TPI
Old Nov 13, 2000 | 08:13 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think its "off" and "warmer" on the CCP (climate control panel). It will flash ECM, BCM, and whatever modules have codes in them.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 13, 2000 | 08:31 PM
Guest
Guest
Posts: n/a
Yep, those are the buttons. Have to press them at the same time. The codes will display on the fuel panel on the left. I cant remember, but theres a common computer 'fit' type of code, I think its E15 or something, its been a while. Its much like a code 33 on a TPI, but much less of a problem and I never did find a solution. Is it the TBI engine? Cleaning the TBI will help out sometimes, they get pretty dirty. I cant tell you what codes are what, but a couple different Caddy dealers were more than happy to tell me what the codes were.
Ghettobird52
Jul 5, 2024 11:18 PM
jhawkeye
May 25, 2022 06:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
