Changing to a 145MPH speedo
Old Nov 12, 2000 | 08:04 PM
matty350TPI's Avatar
What is involved in changing a Canadian speedo over to the 145MPH equivalent in KM/H. I have an 88 IROC and for some reason the speedo only goes upp to 180Km/h somewhere around 85mph. So what is involved in changing over to the larger speedo.?
THanks
1988 IROC-Z T-Top
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch
Old Nov 13, 2000 | 09:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's pretty easy. First, remove the black plastic ring around the gauges, then unscrew the gauge cluster from the car by getting those 2 nuts down near the SES and seat belt lights. After you remove the plastic interior panel under the steering column, you can locate the black speedo cable and follow it all the way to the back of the speedo. If you cram yourself into the pedals, you will be able to reach all the way back. Press the metal tab at the end of the cable while pulling gently on the cluster. It'll pop right out. Work the cluster out around the steering wheel (if you don't have tilt, you'll probably need to drop the column) and you're all set. Once it's on the bench you'll see a couple screws on the back of the speedo that you need to remove. When putting it back in, just line up the speedo cable to the back of the speedo and push. You should hear a click, then you won't be able to pull the gauges back out. That means it's all set and can be screwed back into place.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 13, 2000 | 12:49 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
That's exactly how I did mine Jim! The only difference is, I took the speedo face off and changed the odometer from my old cluster into the new one, so that the mileage stayed right. I'm not super worried about it, but I just like it to be right!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 13, 2000 | 12:57 PM
Jim85IROC's Avatar
I would have too, but I had the new odo rolled back to match my milage. Well, close to it. I drove the car 100 miles over before I had the chance to change the speedo.
The IROC Homepage
Old Nov 13, 2000 | 03:33 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Matt350,
I have a like-new 240km/145mph speedo. It's showing 12.7km on the odometer (I put a couple on making sure the trip odometer worked). Pics available, if you're interested. $125 shipped, money order, certified check or PayPal.
JamesC
Old Nov 13, 2000 | 08:47 PM
JP84Z430HP's Avatar
Car: 84 Z28
Those stupid trip meters are a PITA! I have 2 speedo's that the trip wont work in. There are a couple plastic "hooks" in there that break. I have a third that seems to be ok, I just hate to pull it all apart to change all that crap over. It's an 85'er so I will have my work cut out for me! May I can send it to a speedo shop and have it calibrated also. I got mine pretty close, but it is off by a couple MPH. Luckily it reads faster than I'm going!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
Old Nov 13, 2000 | 08:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My 240/145 speed is still in my race car. It's filling the hole in the dash. It has something like 158k km on it before it was disconnected. odo and trip meter work fine.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
ChevyZ71
Aug 13, 2015 07:30 AM
beachrodder
Aug 7, 2015 04:27 PM
