Engine code 41???
Old Oct 26, 2000 | 02:26 PM
Wolfcoast's Avatar
Engine code 41???
Ok guys.... I think I asked this a few months ago but it was right before I went to sea for 3 months so I don't remember.
I've got an 84 Z28.. L69 5 spd....
I'm getting error code 41..
My autox-ray calls it CAM sensor failure...
To the best of my knowledge I don't have a cam sensor...
What can this be??
The light comes on and stays on...
Engine idles fine, tach seems normal.. The only gauge I have out of whack is the Oil pressure gauge.. Pegged high all the time.
I just replaced the EST module due to a code 42 I had before.... I unplugged the battery and this is the only code I'm getting now.
Thanx,
Randy
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Oct 26, 2000 | 06:57 PM
rondubbs's Avatar
CALPAK fault. This code generally indicates a fault or failure within the CALPAK, which is the portion of the MEMCAL that contains the detailed information about the power train of the vehicle. This could also be caused by faulty CALPAK connections to the ECM, or by an ECM failure.
Old Oct 26, 2000 | 07:48 PM
Wolfcoast's Avatar
So how do I go about troubleshooting this?
Or do I just replace the calpak or ECM chip?
Randy
Old Oct 27, 2000 | 07:54 PM
Wolfcoast's Avatar
Ok. I looked at my chilton's again and realized I missed a line in the error code section...
It says for my engine, L69, error code 41 is:
1 X reference. Is this what you mean Ron?
I have no clue what that reference is...
Randy
Old Oct 27, 2000 | 10:56 PM
rondubbs's Avatar
i really have no idea how ot fix this code... i was just trying to give you some extra info. that info came from the best damn garage on the net website. http://www.racer-x.f2s.com/
Old Oct 27, 2000 | 11:09 PM
Wolfcoast's Avatar
I think I got some good info from Macgyver. He thinks it's the ground to the ECM that's the problem.
Thanx for your help though.
Randy
Old Oct 29, 2000 | 09:50 AM
Wolfcoast's Avatar
Well it wasn't the ECM ground. I'm still stumped on this one. Car seems to run fine, just the SES light on with code 41.
Randy
Old Nov 14, 2000 | 12:19 AM
Ratnose86SC's Avatar
Check your connections at the distributor and ESC.
Im chasing that code too, except my cars running like a rabid butt pirate.
Old Nov 14, 2000 | 01:36 AM
Wolfcoast's Avatar
Sorry, forgot to update the post. hehhee
Found the problem. The EST connector to the dist. looked connected but wasn't. That was all it was. Thanx for all your help.
Randy
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
