Help with mystery motor...
Old Sep 9, 2003 | 11:23 PM
JayB's Avatar
I have the opportunity to purchase a motor...it came out of a 1 ton chevy truck. Its rough shape, it supposedl has 98k on it, but it may make a really good rebuilder motor for my first project, the only numbers i was able to get from the seller are
T0611ctu
He believes that the 11 could be a seperator for t06 and ctu
Any help????
Could be a 400 or 350???
Old Sep 10, 2003 | 07:09 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
CTU, if correct, is not a truck engine. Truck engine codes start with "T". GM never put 400 SB's in 1 ton trucks. CTU is a valid code for a 1976 Caprice 400 SB engine.
Old Sep 10, 2003 | 07:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it is a 400, the harmonic balancer will have a big chunk missing out of it.
Old Sep 10, 2003 | 10:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look for 3 freeze plugs. Thats what gives away a 350 from a 400. the 350 only has 2.
Old Sep 11, 2003 | 05:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Only the early 400 blocks have 3 freeze plugs.
A side view of the 509 casting 400 block above:
diana227vegas
Jul 8, 2016 12:27 AM
Gordonr1973
Sep 29, 2015 11:59 AM
camarohelp
Sep 12, 2015 05:45 PM
luvofjah
Sep 3, 2015 07:08 PM
T and A
Apr 17, 2001 09:50 PM
