How do I test my EGR or can it be done?
Old Nov 15, 2000 | 04:18 PM
HOOK's Avatar
I was putting my intake back on my car today and got to wondering about the EGR and if it
could be bad. I was wondering if their was a way to test it. I did not want to get the car back together and that be a problem. Also, This car had the smog pump removed. I was wondering if their is a right and a wrong way to do away with the smog stuff or not. Thanks for any help.
Old Nov 15, 2000 | 04:37 PM
ede's Avatar
ede
if you stick your finger(s) under it you'll feel opening. push up on the diaphram should make your engine stumble. i think you could use a vacumn pump and do the same thing.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 16, 2000 | 08:18 AM
jrr's Avatar
jrr
Also, be sure the EGR passages aren't full of carbon and soot. Even if the EGR valve works and pushing up on it causes a rough idle--if the passages are clogged, you'll still get the inevitable pinging while you're on the road.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
