Ohms of Plug Wires ??
Old Sep 14, 2003 | 03:19 PM
nathan2003's Avatar
Car: Camaro
Can anyone here tell me what I all need and how you are suppose to check the ohms of your plug wires... I'm afraid a few might of gotten fried or might be bad. I already have two sets of wires so I figured if ones bad I'll just steal it outta the other set cause I don't wanna buy a whole new set when I already have two. I looked in my chilton and understand how many ohms they are suppose to be just needa know how to do it... thx..
Vetter
Old Sep 14, 2003 | 03:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You need an ohm meter...but suggest you get a DMM, so you have the ability to not only check ohms, but voltage and current as well...digitally ofcourse
Once you have a meter, select the "ohms" range...looks kinda like an upside down "U".
Connect one lead to one end, the other lead to the other end of the wire and a reading will be displayed...depending on the type of meter you may have to select a "range" to be read...
i/e some meteres will have different selections...like 0-10, 0-1000, 0-10,000, etc. If your meter has an auto-select feature, you're good to go, just note the digits it reads.
Old Sep 14, 2003 | 03:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
BTW, DMM is "Digital Multi Meter".
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
