Speedo not working after motor swap
Old Nov 10, 2000 | 11:31 AM
90FFBird's Avatar
I have just done a 5.0TBI to ZZ4TPI swap. I used an '89 computer and wiring harness that seems to work fine. The car runs great except for a few "bugs". One of these is the speedometer. The '90 computer controlled the speedo. It appears that the '89 computer is not equipped to handle this task and I need to find a reasonable solution (no speedo with this engine is a bad combination). To complicate things further, the original 700R4 tranny has been replace with a '97 T56 using a Cyberdyne calibration box. This setup worked great before the engine/computer/wiring change. I know this may be alot to ask, but I'd like to leave the instrument cluster alone if possible. Any help/ suggestions would be greatly appreciated. Thanks, Rob.
Old Nov 11, 2000 | 08:44 PM
90FFBird's Avatar
anyone have an idea?
Old Nov 12, 2000 | 06:04 AM
z28wiz's Avatar
well i had a problem like that. I put in my 700r-4 and being the genious i was at first, forgot to put in the speedo gear into the transmission. So if you have an electronic speedo i think i dont think its gonna work right unless you put a speedo gear into your transmission and plug in the connector from the harness.
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!(update 11/01/00 pulled engine
visit my page http://www.geocities.com/motorcity/pit/8410
2001 camaro SS LS1 onyx balck, SLP dual/dual center exhaust which brings horsepower to 335hp and 350ftlbs of torque, T-tops, 6 speed, Hurst shifter, cags!, power everything
Old Nov 12, 2000 | 04:00 PM
90FFBird's Avatar
The biggest problem I have is that the computer was changed. The computer I'm using now doesn't recognize speed sensor input. The harness that came with the computer (factory '89 GM harness) didn't come with the two wires in the harness to pick up the signal from the transmission. I was trying to find a way to put the signal directly into the speedometer so it would work. I'd also like to get the cruise controll working too, but I'd be happy to just get the speedo working for now.
Old Nov 12, 2000 | 05:36 PM
mtx28's Avatar
90FFbird, sorry i cant help much with your topic, i just watned to know how happy you are with the performance of the ZZ4. im considering that engine, or something along the same lines of it. does it perform as much as you'd like it to?
Old Nov 13, 2000 | 08:09 PM
90FFBird's Avatar
Performance wise, the ZZ4 is awesome. I've driven a few fast cars but this is a very strong engine. I'm sure there is alot of potential I haven't tapped yet with the TPI setup I have. But at least I have somewhere else to go with mods. I got a good deal on the intake/computer/wiring set and made use of it. The difference in this car is nothing short of amazing with the mods I've done this year. For now the performance is plenty..... but you know how that goes. There's always room for more later =). First I think I'l work out the kinks before I generate more.
Old Nov 16, 2000 | 10:33 AM
90FFBird's Avatar
Anone else have an idea?
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
st.evel07
Aug 13, 2015 06:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
