dart intake
Old Nov 15, 2000 | 09:49 PM
SCOTTCAMARO1's Avatar
dart intake
has anyone heard about or used the dart intake rated from 1500-6500rpm its a dart2
Old Nov 16, 2000 | 06:22 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I think it is basically a clone of a perfomer rpm airgap. I have not seen any dyno info.
Old Nov 16, 2000 | 11:58 AM
md's Avatar
md
I just used that manifold for a 406. It’s actually made by World Products. It’s the Sportsman, right? Dart and World recently split company so it gets a bit confusing who actually makes what right now.
Anyway, I went with this manifold because my supplier recommended it and I wanted to try a dual plane for this build. My supplier does port work as a main business and sells parts on the side. He likes this intake over the RPM and RPM air gap because he say’s it flows better. It has a notch cut in the plenum divider that aids in high rpm flow. It also has heat cross-over which is preferable for a street engine. The 406 dyno came in at 450 @ 5300 with a very mellow cam 226/236, 114 LSA. I have a more aggressive cam that I’m going to try in a couple weeks. I’m pretty sure the numbers will be around 480 with the different cam and same manifold.
Mike
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
