Need help installing interior door handle
Old Sep 15, 2003 | 01:22 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Mine broke, so I had to buy a new one for the passenger side. So how do I go about taking out the old interior door handle and putting in a new one?
86 T/A
Old Sep 15, 2003 | 03:10 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I just recently replaced my driver side handle, You can either drill out the rivet on the out handle, or pry it off, I pryed the handle until the rivet popped off, but you'd be better to drill it out, its less risky. To put the new one in slide it in place (theres a tab on it that slides into the door, hookup your rods to the handle, and find an appropriate nut and bolt to hold it, or you can put a new rivet in it, I did the new rivet, mainly because I work in a body shop and have easy access to all that stuff. The rivet will hold it more securely but a nut and bolt will work just fine(Just more of a pain in the a** to get it tightened)
Old Sep 15, 2003 | 03:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Remove the plastic cover, which has a Torx screw holding it on. The handle itself is pop-riveted to the door panel. Drill out the old rivets, install the new handle with pop rivets.
Assuming 'Birds are like Camaros, that is.
Old Sep 16, 2003 | 05:43 PM
warrior_91's Avatar
Car: 86 T/A
What does the rivet look like? I need a pic. Can I go buy one from an auto parts store?
Old Sep 16, 2003 | 06:23 PM
five7kid's Avatar
You've got PM.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
1nastygta
Aug 8, 2015 07:38 PM
