Need advice, have to change oil pan gasket
Old Nov 15, 2000 | 07:13 PM
Stell1579's Avatar
since i changed my timing chain, the pan leaks. any advice on how to drop it?
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Nov 15, 2000 | 07:25 PM
Bort62's Avatar
Wich seal Did You use On the front of the pan? There is a thick one and a Thin One, If You used the Thin One then It is going to Leak
Personal experiance.
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Old Nov 16, 2000 | 11:13 PM
Stell1579's Avatar
actually its the rear thats leaking, the front leaked but a lil RTV solved that one. i know the rear isnot the main seal because the flywheel is dry, and spot from the mainseal to the oilpan (small space) is also dry but oilpan gets soaked and the outside of th eflywheel, tranny pan gets wet aswell
i think its from lowering th epan slighly when slippin gth etiming cover back in. anyway i got a nice gasket from the dealer, 1 peice rubber and a mettle ring around each screw hole to prevent crushing th egasket
-Stell
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
