Deck Height/comp. question...
Old Sep 16, 2003 | 01:41 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Easy one... I need to check my comp.
4.030*3.75 ( 5.7 rods) and 65cc heads
Flat top -5.4 cc pistons
My pistons says: 0 deck height at 8.995 does this mean I have
0.030 in piston clearance?
/N.
Old Sep 16, 2003 | 05:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Only way to know is to measure it.
Stock deck height (distance from centerline of crank to deck surface of block) is 9.000", -.000 or + .035" or so. Most stock blocks are at about 9.025-9.030". That means a piston with a nominal height of 8.995" is most likely about .030" down in the bore.
Again, the only way to know is to measure, it's different in every block. But that's a reasonable guess.
On the other hand, a guess isn't really good enough for being bothered with all that calculation.
Old Sep 16, 2003 | 09:13 AM
Vader's Avatar
RB is correct (as usual). In my few builds, I have measured a rough average (by recall, not any real notes) of about -0.015 deck height on the "average" SBC. I've used that number as an average or typical dimension on the downloadable calculator:
Engine Calculator.xls
That works with either MS Excel or Corel QuattroPro.
Old Sep 16, 2003 | 03:27 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
.......Nice to hear from you again vader, its been a while.......
Thanks for the program, will be shopping new heads now with 72cc chambers. Prolightning or jegs..............
Thanks/N.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
skinny z
Oct 5, 2015 06:23 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
