84 L69 rebuild questions on vortec heads
Rebuilding my tired L69 Carb. I want to go with vortec heads. A freind gave me two L31? heads from his 97 pickup with only 9000 Km on them.
Just what do i need to us them . If some one has done this before please let me Know what dome to use and a cam to match!
Thanks in advance
Fully restored 84 TA original factory spec (sucks) Mods when the kids grow up "Sigh" no money!
Thanks in advance
Well, If they are The Vortech heads, You will need to Get the Edlbrock performer RPM manifold for Vortech, as the bolt patterns are Differnt.
other than tht...
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
other than tht...
Transmission: 4L80E/4L80E
I don't have the Vortecs, but have looked into it. If you bolt them on as-is, you're going to take a compression hit because they're 64cc. You can get them milled, but take your new Vortec manifold in at the same time to have it shaved to match. You could use domed pistons, but I haven't seen any listed for 305's - flat-tops are the best I've seen, which I believe your L69 already has.
If you're going with a bigger cam, watch the total lift. I forget the number, but they can't take a hefty amount without new springs.
If you didn't get the rockers, you'll need self-aligning pieces, which your L69 doesn't have.
They may also may not have the exhaust cross-over passage, so your EGR will not work. That can cause pinging problems if you don't redo your timing curve (there's another post on that somewhere on these boards).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
heres the real deal, I run vortec with a C and not a CH (pet peave). I run .470 lift on the stock springs and also have a performer RPM. These heads are great, check the time and that was with just 2 runs. Just get them milled 45 thous and bolt on the performer RPm and your set. oh yeah, stock exhaust manifolds wont bolt up either, so you best get headers as they will work.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
