Fuel woes
Old Sep 21, 2003 | 02:22 AM
MasterEvilAce's Avatar
Fuel woes
Ok, so I think i've tracked down the bad starting problem (takes a while to turn over)
after you shut off the car, the car seems to have pretty much no fuel pressure at all, at the engine... turned the key, and tested again, and it seemed to have some pressure (squirted out)
changed the fuel filter, and it still seems to have this problem. :/
sound like a fuel pump problem?
.... reading through some posts using SEARCH it sounds like it could be a few things.. fuel pressure regulator? fuel pump, maybe? injectors... leaking? hmmmmmm.... when i changed spark plugs a week ago, i noticed one sparkplug seemed to have a thin coat of gas on it.... whcih makes me think something is wrong there...
Old Sep 21, 2003 | 08:02 AM
Vader's Avatar
Without a fuel pressure reading, any diagnosis will be pure speculation. Does the pump run for two seconds when you first turn on the ignition?
Old Sep 21, 2003 | 11:38 AM
two seconds? hmm.. seems to prime constantly, until i start it up
that is, i've never really WAITED to see how long it's primed..
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
