high idle ,wont start
Old Nov 20, 2000 | 02:45 PM
88FormulaWS6's Avatar
my car has a high idle , but i have ti step on the gas while cranking it to start. its a tpi you shouldnt have to do this anyone have any ideas?? i had the computer checked no codes came up twice so i dont think its sensor related thanx for any suggestions.
88 Firebird Formula WS6
305 TPI 5 speed
B&m Ripper shifter
MSD Blaster coil
TPIS airfoil
Hypertech fan switch
TPIS 170 degree thermostat
3 inch flowmaster exhaust
alt +crank pulleys
15.084 @ 92.41 mph ALL RACING MODIFICATIONS PERFORMED BY JOHN-OOTZ RACING INC.
Old Nov 20, 2000 | 03:31 PM
snakeskinner's Avatar
you need to get a scanner on it to see what's going on. it could be the tps or the iac or several other things. you may have injectors leaking and causing a minor flooding situation and by opening the throttle you are allowing enough air into the engine to compensate. I would find someone with a scanner and check out the tps readings first of all. it should read around .54 volts with the throttle closed and go up to around 4 volts at WOT.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
