What the HELL have I gotten myself into..oh my god!
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I cant get the damn fuel rail bolts off...I have tried everything...one of them is striped. I have tried vise grips and all...
How do I get them off?.....PLEASE HELP!
Well I have been taking apart the top half of my TPI to change the intake gasket and JESUS CHRIST, how in the hell am I going to put all the back together....LOL
Wires, hoses, vaccums, lines...on and on and on.......LOL
There no turning back now though Im in to deep....
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Performance Resource Chip
Flowmaster Muffler
Throttle Body Coolant bypass
TPIS air Foil
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
AC Delco Rapidfire plugs
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Flowmaster Muffler
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Car: Take
Engine: Your
Transmission: Pick
Thats what I thought when I ripped out my fuel tank, cut all of my Carb fuel lines out, gutted my dash board to redo the wiring, yanked out the engine wiring harness, and yanked the carb/intake off. Ooops, to late to turn back now!
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
LOL!
Any idea on my FUEL RAIL BOLT problem...
What do you gys suggest I try?..
Guest
Posts: n/a
Stripped eh? About the only thing I can think of is to drill the head off. Once you do that, you can pull the rail up off the leftover piece, and then you should be able to get a better grip and better access to that once the rail is off to remove it.
bbtw you shouldnt need to remove the fuel rail assembly to take the Intake off.
Once the Runners and plenum are off, You can get to all the intake bolts.
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
I dont know about the stripped bolt, but as for putting everything back together...The first time i took my intake apart I took a couple of pictures with a digital cam, I ended up not really needing them, but it sure does make you feel better knowing you have them, and also i clearly labeled everything!!
dimented24x7
Sep 6, 2015 03:51 PM
