multi grade oil
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
multi grade oil
i've done a search but didn't find anything. Does anyone know at what temps a multi grade oil switches grades? In other words, when (at when temp) does a 10w30 oil act like a 10 weight and when does it act like a 30 weight? thanks!
Transmission: 4L80E/4L80E
It doesn't work quite that way. The oil is tested at low temp and assigned a "W" viscosity, and tested at high temp for the no-letter viscosity.
That's all there is to it.
Oh, the "W" stands for "winter", not "weight". A straight 30 weight is "SAE-30", not "30W". And, 20W-20 is actually a multi-viscosity oil.
skinny z
Oct 5, 2015 06:23 PM
