smog pump
Old Sep 23, 2003 | 04:22 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
smog pump
Well, I looked on the tech article, but that was for a fuel injected car, and I showed the diagram to my dad, and he said I have a different belt routing for my carburated 305. I was just wondering if any of you have taken your smog pumps off on your carburated cars and how do you do it?
Old Sep 23, 2003 | 04:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mine is off for the time being, but needs to go back on for emissions testing next month.
The bracket unbolts from the block. The belt is dedicated to the pump. There are a couple of vacuum lines going to the diverter valve (which I also don't have on right now), they need to be plugged. On the manifolds (headers, in my case), remove the check valve & hoses, and put a brass pipe cap on the fitting where the check valve went. Or, remove the pipes from the manifolds and plug them there.
The only benefit to all this is to clean up the engine compartment a little bit. The pump has zero effect on performance.
Old Sep 23, 2003 | 04:38 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, they quite testing in MN so I removed all my smog stuff (84 Z28 L69) and stored it all away because you never know. I just removed everything including the diverter valve. Just unplug the wiring and tuck them away from the hot exhaust. I pluged the fresh air pipe that is on the converter and headers. I put a block off plate on the int. where the EGR goes. I removed the chercol canister (used the space for a vacuum can for the power brakes) and rerouted the hoses. Oh, and this will not turn the check engine lite on. At least not on my 84.
Auggie
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
