EGR Valve?\
Old Nov 19, 2000 | 09:52 PM
Pino91Formula's Avatar
EGR Valve?\
Hi all ,, here is my delema , i had to replace my egr valve two weeksago , well thats what the car told me atleaste , code 32, well last night the engine light pops back on , i went to check the code and it was 32 again, i was wondering if anyone has had any problems like this? if maybe something els is making it throw the egr code? , im going to order one from GM , last one was from Auto Zone and was a chore to find too. if anyone has any ideas or input , it is greatly appreciated ,
Pino
91'Formula
LB9 305 TPI 5-speed
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Old Nov 19, 2000 | 10:07 PM
Vader's Avatar
Pino,
You should check the EGR solenoid valve (next to the distributor). It controls the vacuum signal to the EGR valve itself. You should also verify the connections from the EGR diagnostic temperature sensor. You can test the sensor the same as you would any other GM temperature sensor. Make certain all vacuum hoses are in good condition.
While the valve was off, did you inspect the EGR passages in the intake to be sure they were not clogged? Since the valve is already installed, you can test for this by reaching under the plenum and manually opening the valve by lifting on the diaphragm under the vacuum actuator. The engine should begin to stall with the valve open at idle.
HINT: Do this when the engine is not completely up to temperature, since the plenum and intake get warmer than you want to touch after running for several minutes.
Another possibility is the aftermarket EGR was not correct for your engine. If it was one of the generic units with the control oriface washers that stake into place, it may not be optimal for your engine. Those are made to fit a large number of engines and barely function on all of them. Your tolerances may be off just enough to prevent proper operation, especially with a positive backpressure EGR system.
I would expect that you could get a refund from Ought-Tow-Zone if you return the generic valve with a reasonable explanation of the problem.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 21, 2000 | 11:35 AM
craig90formula's Avatar
I get an intermittent 32 on my 90 LB9. I have checked the valve and the solenoid and all seems ok. I remember reading in another EGR post or maybe one of the tech articles here that people have seen 32's after gutting their cats. Mine are empty also, I was just assuming that may be it on mine.
Old Nov 21, 2000 | 07:24 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
If the backpressure is reduced than the valve can't work right. I needs backpressure on it along with vacuum to open. I was thinking about taking mine apart and trying to weaken the spring to compensate for less back pressure. I don't know if a EGR valve can be taken apart though without breaking it. Nobody else seemed to know if this could be done from my other posts.
'89 Formula 383 TPI
Old Nov 21, 2000 | 07:44 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I have a flowmaster exhaust and a gutted catalyst and no code. I will see if it stays that way when I eventually do headers/3" exhaust.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 21, 2000 | 08:31 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
hey craig, i had same problem, new delco egr and delco sensor and still got intermittent 32 only on startup sometimes. then replaced temp sensor on egr as what vader said earlier in this subject, have not seen code 32 since and car runs noticably better, sensor was like 10 $ only bad thing is plenum must be removed to replace temp sensor.
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle
Old Nov 21, 2000 | 08:44 PM
voltran's Avatar
When I changed my EGR, I bought it from some parts shop. As soon as I put it on the light came on. Then I returned that and got an AC Delco one. No problems since then.....
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
