Oil
Old Sep 24, 2003 | 02:23 AM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Oil
Hey all, I have a 305TBI with 27k miles on it. I run Mobil 1 Synthetic 5w30.
Anyway, when I start the car, the oil pressure stays arount 40, but as the car gets hotter and hotter it drops while idling. Now, no matter what the temperature of the motor, when ever I hit the gas, it does go right back up to perfect pressure, but at idle, it will go as low as almost into the start of the red. But say, at 2k RPM, the pressure will be at 30.
Also, I just replaced the oil pressure sending unit, and it did nothing.
Is that just normal for the Synthetic or motor?
Thanks!
Chris
Old Sep 24, 2003 | 02:39 AM
rezinn's Avatar
I'd probably run 10w30 next oil change. The way you've got it is fine, though.
Old Sep 24, 2003 | 05:19 AM
ede's Avatar
ede
that's pretty much how it should act.
more rpm= more psi
cold oil = more psi
hot oil= less psi
Old Sep 24, 2003 | 02:11 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My 305 TBI did the same thing. Had 113k miles tho. I think my bearings were going out. The pressure would drop enough to sometimes kill the car. Oh well I have a new 350...never goes below 30psi now. Except when the car is off
Old Sep 25, 2003 | 05:16 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I had a similiar problem with my 88 Grand Prix. It had the 3.1 engine, same as base F-bodies.... It would read super high sometimes, peg out, but a few times, it would read like a normal gage. Before I went to synthetic 10W30, it would peter out to next-to-nothing, light the idiot lihgt, the whole nine yards. Synthetic fixed the problem... Shrug. Old car, don't own it anymore...
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
