Help! Car is bogging with any amount gas given...
Old Nov 22, 2000 | 09:51 PM
crazeinc's Avatar
Hey guys. It's been about 2 months since I've driven the car, but I'm a little worried. Whenever I gave it anymore than a slight tap on the gas it would stall and then kick back in at around 2200rpms, but it was still kinda weak. I figured the car just hadn't warmed up yet, but the engine temp was 200* before I turned the water pump on. I never remember having this problem before, do I just need to "break it in" some more and this bogging will just go away? The 4.10's gears are not the proper gear to go with my current engine setup so that probably doesn't help, but there has never been bogging this bad.
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
NOS Sportsman Fogged
10 bolt braker
Coming to a street near you in the spring...
The car's website
Old Nov 23, 2000 | 11:04 AM
Vader's Avatar
Craze,
What are you running for a fuel system? It could be that your carb (if equipped) isn't warming the choke enough to relax the high idle cam.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 23, 2000 | 11:34 AM
crazeinc's Avatar
Yes, Vader, I am running a carb'd setup and there is no choke on the car. I thought that when the engine reached operating temperature that the carb would respond normally, is this not the case? Does the carb need extra time to "warm up"? It was 20* outside last night, so I'm sure that didn't help, but I had it running for approx. 10 minutes before I shut her off.
Old Nov 23, 2000 | 02:25 PM
crazeinc's Avatar
I took it to the gas station probably for the last time until spring and it was better than before once I gave it about 10-15 minutes to warm up. It wasn't perfect, though...I wonder if I just let it circulate even more that it will finally be OK. The idle was high and it was choppy.
The damn engine is a bear, though, I was able to break my brand new Nitto Drag Radials quite easily. I don't like cold weather!!
Old Nov 23, 2000 | 10:53 PM
B84305-Streetmachine's Avatar
if its a carb......and it chokes on every amount of given gas......sounds like a stuck bowl needle in your carb......ive had that happen on a carter competition series before.....not nice
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
killer777
Aug 8, 2015 02:47 PM
