rpm guage bad
Old Nov 23, 2000 | 06:33 PM
88transam5.0's Avatar
rpm guage bad
I just replaced my smog pump and reconnected the battery, started the car and now my rpm guage is not working right. Is the guage going bad or what else could be causing this. It doesn't stay steady, bounces around and at times stays at zero. can anyone help!
88 transam 5.0 tpi
Old Nov 24, 2000 | 12:23 PM
Vader's Avatar
88,
Check your wiring grounds. Check the TACH connection at the distributor, and make sure the tach wiring is not routed too close to the ignition coil.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
xxx3man`
Sep 23, 2015 10:37 PM
someone972
Aug 30, 2015 12:52 AM
86IROC112
Aug 21, 2015 07:20 PM
355sbcTPI
Aug 19, 2015 04:38 PM
