Milled,Decked, Extruded Definitions
Old Sep 28, 2003 | 11:57 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What does Milled mean? What does decked mean? What does extruded mean?
Old Sep 29, 2003 | 12:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A mill is a type of material removal machine. When you "mill" your heads, you remove material from the sealing surface to the block.
"Decking" is milling the block on the "deck" surface that seals to the head.
These operations are done to true up the flatness of the sealing surface, and to a lesser degree (but which is more commonly discussed) as a performance improvement for compression ratio or quench area changes (need "quench" defined?).
To extrude is to force through under pressure. You're probably referring to a process called "extrude honing" which forces an abrasive paste through passages to smooth them out.
Old Sep 29, 2003 | 04:53 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks alot five7kid! That helped alot. And yes what is "quench"?
Old Sep 29, 2003 | 04:58 AM
ede's Avatar
ede
quench is the area between the piston and chamber. it's a variable depending on piston design, gasket thickness, and chamber size, and a few other factors
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
