Engine Clatter
Old Sep 30, 2003 | 10:34 AM
EJ Coons's Avatar
Car: 1986 IROC Z
Engine: Gutless Wonder 305 4bl.
Transmission: 5 sp.
Engine Clatter
I have a 86 iroc 305 carb. getting a lot of valve clatter going up grades. have been told this is timing even possibly changing the thermostat to a lower temp may help. (may be runnng hot) Car idles a little rough. I have checked crancase pulley and block for marks and degree numbers and can't find anything to reset timing with a light. Is this done via computer inside distributor?. I'm new to cars as you can tell. Your opinion needed. Thanks
Old Sep 30, 2003 | 11:07 AM
ede's Avatar
ede
there are marks on the dampner and the timing cover, keep looking i bet you'll find them. look in your manual for a pic of the location, most manuals have them, you'd use a light to set base timeing, not something the ecm controls
Old Sep 30, 2003 | 11:08 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Have you checked your computer for any codes? That's the first thing I would check. If you go to your local Autozone, they'll check them for you.
Pretty cood instructions on doing this...
http://sethirdgen.org/dtc.htm
Old Sep 30, 2003 | 11:40 AM
ede's Avatar
ede
as for your problem it sounds like preignition to me. try changing the timing or octane, maybe even both
Old Sep 30, 2003 | 11:47 AM
Keith_Indy's Avatar
Engine: 305 LG4
Yeah, forgot to mention that too... Pre-ignition or detonation.
Found this helpful article that has some suggestions.
http://www.federal-mogul.com/cda/con...9_7525,00.html
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
