How to connect handheld tach
Old Nov 18, 2000 | 04:39 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
OK, I got this Actron tach/voltmeter to set the correct minimum air and idle speed but I can't figure out where to connect the green clip. It has a black clip that connects to engine ground, and the green one to the coil, or so the intructions say. They're really ambiguous so i can't figure this out. Can anyone tell me where the green clip hooks up? Thanx in advance.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
Old Nov 18, 2000 | 04:56 PM
SeanSullivan's Avatar
The distributor side of the coil.
Old Nov 19, 2000 | 11:17 AM
Vader's Avatar
88,
This terminal should have a "TACH" label on the distributor head.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 25, 2000 | 06:15 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Doh!!! I looked all over the coil for the TACH terminal. Then I read this post again to find out I should have been looking at the distributor. What color is the TACH terminal wire? Thanks.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
Accel cap and rotor
$750 L98
Feb 1, 2025 02:25 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
