EGR vlave question
Subscribe
Nov 24, 2000 | 10:51 AM
will the "Service Engine Soon" light always be on if you have a bad EGR?
Reply 0
Nov 24, 2000 | 10:55 AM
It sure can. It happened to me.
- Mike Harvey -
Reply 0
Nov 24, 2000 | 10:58 AM
is this a trick question? i'd guess that under some conditions you'd have a bad egr and no check engine lite, but normally i'd say a bad egr would set a code. on the other hand a code set for the egr doesn't mean 100% for sure you have a bad egr. there are other parts in the system. you need to look at a flow down trouble shooting guide for a bad egr and follow it out to find your problem.
-=ICON MOTORSPORTS=-
1st & 3rd
Reply 0
Nov 24, 2000 | 11:11 AM
i was asking because my light never comes on yet i think i have an EGR problem...at low speeds i get some detenation and slight pinging...and i put premium fuel in and it helped a little bit so could this actually be the timing?
Reply 0
Nov 24, 2000 | 11:37 AM
Here is the best way to tell if your EGR valve is leaking and bad. Spray WD-40 at the base of the EGR valve. Don't worry nothing will catch on fire and make sure the engine is running. If the EGR is bad then the WD-40 would be sucked in by the EGR. It's a simple easy way to find out w/ out being a mechanic
- Mike Harvey -
Reply 0
Nov 24, 2000 | 11:50 AM
BB,
The EGR system is not normally operational until you are at a part-throttle cruise under moderate loads, like highway operation at 50-60 MPH. The EGR should be fully closed when accellerating or on a cold engine.
The detonation you are experiencing is more likely a function of lean mixture, advanced timing, poor fuel, of heavily carboned chambers/valves.
Does the SES lamp illuminate when you first turn on the ignition?
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Reply 0
Nov 24, 2000 | 08:23 PM
Vader the SES light does turn on when i start the car...is this somehow imperative to my problem?...thanks
Reply 0
Nov 24, 2000 | 08:28 PM
No, Vader was just making sure that your "no SES light" wasn't because some knucklehead yanked the bulb out.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Reply 0
Nov 26, 2000 | 01:26 AM
i had some crazy detonation problems with my 85 tpi. i changed the timing chain and now it runs excellent. if it has the chain from the factory and has a lot of miles the chain may be streched and could also be skipping a tooth. just my experience. i still have the check engine light coming on only on the highway that i still cant get rid of though. i may have an egr problem, but the detonation is gone now!
beau-t-ful yellow 85 iroc
Reply 0
Subscribe
