9.5 compression, what kind of gas?
Old Nov 26, 2000 | 08:51 AM
fsg
Guest
Posts: n/a
yes, i'm planing to change the heads on my 305 carb, it has 60cc and the small 1.72/1.5 valves wich gives me a misserable 8 compression. i can buy a set of 416 heads (58cc 1.84/1.5), maths shown a compression of 9.5 aprox. the question is:
should i keep using ordinary unleaded or go to SUPER unleaded?
thank you very much...fern.
Old Nov 26, 2000 | 09:15 AM
ede's Avatar
ede
unless you have a typo in there 2cc isn't going to get you 1.5 more points of compression. if you don't have a typo run the same fuel you've been useing and see how it works.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 26, 2000 | 10:18 AM
Vader's Avatar
FSG,
By comparison, flat-top pistons with four valve reliefs and 58cc chambers on a 305 at standard deck height and ring locations yields about 9.5:1 static compression. If your piston volumes are altered, deck height changed, gasket different, etc, you'll have to calculate the differences. Stock components and 60cc heads should get you about 8.9:1. Double check your stock castings. I think you'll find a different volume than 60cc.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
86iroczwv
Sep 3, 2015 06:21 PM
