Wireharness
Old Oct 1, 2003 | 12:10 AM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
Wireharness
I'm trying to remove the wiring harness from a 90 camaro and I can't figure out how to get it out of the fender. Can someone help me please?
Old Oct 1, 2003 | 01:26 AM
onebinky's Avatar
You gotta drop the fender to do it. After you get the fender off, you have two tabs to press on the plastic housing that passes through the fender. It's just a pressure fit after you push the clips, so with a little work it'll pop right out.
Here's a rough pic of what you want. It's the harness that passes under the antenna motor.
Matt
Old Oct 2, 2003 | 11:24 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You dont have to remove the fender to do it, remove the pass kick panel, squish the top tab and push out remove the fender liner, pull it up through the little hole in the frame.
Old Oct 2, 2003 | 03:12 PM
onebinky's Avatar
that would definately be easier if you could get it, I've always had to pull the fender off to do it though.
Matt
Old Oct 4, 2003 | 02:05 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Maybe its a power antenna thing, but i've never had to remove the fender to get it out, only takes a sec.
Bobby Suth
Jun 6, 2012 02:01 AM
88tpi350
May 31, 2008 07:05 PM
Imadude_134
Southern California Area
Oct 14, 2007 10:25 PM
