emissions test
Subscribe
Oct 1, 2003 | 02:51 AM
anybody know hard its gonna be for my 84 berlinetta to pass emissions??? any horror stories or tips would be appreciated! I really need it to pass
Reply 0
Oct 1, 2003 | 06:19 AM
depends on the test and what you have or haven't done as well as the condition of the tune up and overall preformance of the engine
Reply 0
Oct 1, 2003 | 09:24 AM
do a search on emissions....you'll find lots of cool stuff!
Reply 0
Oct 2, 2003 | 09:14 AM
The last time I took my Black Berlinetta in for the emissions test ( before it was wrecked!) I preped it first. The car was a 305ci V8 automatic. I wanted to get the car tested BEFORE I did all the work to re-install the smog system. I had completely removed the smog system ( manifold tubes, smog pump, AIR system, ect) because the "visual" test was not required here in RI.
1)I burned 2 full tanks of Ultra 94 octane
2) Put a bottle of fuel system cleaner in the tank on second fill up.
3) Sprayed 1/4 can of carb cleaner thru the carb while cleaning it with a brush
4) Changed the plugs ( needed it anyway. )
The car passed the state emissions test with flying colors. The total time involved with prepping the car this way for the test was 1-2 hours. I will add that the cat converter on the car was in good shape as well as rest of the exhaust system. ( the AIR tube was plugged with a screw !) MANY shops around here will fail a car with bad pipes on it !!
Good luck !
Reply 0
Subscribe
