difference between LT1 long block and...
Old Oct 1, 2003 | 10:12 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok soon enough i'm gonna get myself an LT1 block for my 86 Trans Am. I need to know if there is a diffference between the long block and short block. If there is will it still fit in the car exactly the same. I need this to be as easy as possible on my part.
Sooner or later i'll convert it to a LT4 giving me a garanteed 450hp.
And another question will it be better for me to keep my current transmission on my 305 ci block, or to get the LT1 engines transmition and use it. I mean i know mine has prolly more wear and tear but its $650 more than without the transmision. Its like $1500, with it and $850 without. Which would be the better choice, the engines both have same mileage about 80k miles, mine has 120k currently.
Old Oct 1, 2003 | 10:58 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
short block = engine with internal components (rotating assembly/camshaft/timing chain) - sometimes have oil pump & pan, sometimes do not
long block = short block + cylinder heads - always come with oil pump & pan
As for the tranny, neither the T5 or T56 are rated for 450 HP, but the T56 is definately stronger.
If I were you, I would keep the T5 until you break it - then upgrade. I currently have a T5 behind a 408 SBC putting out an estimated 420 horsepower.
edit:
Just realized, you didn't specify manual or auto tranny. If you have an auto, I don't know the difference between yours and one that would come on an LT1 equipped car.
Old Oct 2, 2003 | 07:06 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you would have a lot more room with the short block since it lacks heads, an intake, a cam,an induction system, and probably an oil pan and pump. the long block will take up considerably more room.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
MoJoe
Sep 24, 2015 09:12 PM
sreZ28
Aug 14, 2015 07:48 PM
