5.0 Litre Crossfire Intake Question
Old Nov 26, 2000 | 12:52 AM
nesluopetan's Avatar
I have a 82 Z28 camaro, its almost fully restored, nothing wrong with it at all, no dents, scratches, 60,000 miles on the car, so i was wondering, what does intakes actually do for your car? how much horsepower would i actually get, and does it hurt the engine at all? i have been looking for a intake and i cannot find one for a crossfire, or am i just not looking at the right one? someone please reply and tell me where i can find one, thanks so much guys.. and maybe from 1 to 10 on how hard they are to install.. thanks..
Nate
Old Nov 26, 2000 | 01:02 AM
mtx28's Avatar
too bad u didnt post a few months back, i just took off my xfire injection and threw it in the trash. i wouldnt have the foggiest idea of where to get one, cept to look around in a lot of junk yards, are pretty rare i'd think, just bc they suck so bad if your trying to restore, then good luck finding one, if your just putting the car back together, then i advise a carb. or other type of injection. they offer no more performance than a carb could give. thats why they got discontinued.
Old Nov 26, 2000 | 03:01 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I assume you are talking about replacing your stock manifold with an after market improved version. Don't waste your money. Go to this site http://www.crossfire.homeip.net/
and learn how to make your CFI move out. Look at my sig and my 1/4 mi results. At first it looks like I should be doing better, but the long block and heads are late 70's, smogger, bone yard specials. I've spent less than 800 bucks. The CFI DOES work, you just need to know what to do to it - lots of hand porting.
'83 Trans Am. 400 CID, 224/234 crane cam, Summit aluminum roller rockers, hand ported intake, home bored 2.09" (53mm) throttle bodies, MSD 454 injectors(75 lb/hr), Holley 255LPH fuel pump, custum modded FPR w/Vacuum port added, Edelbrock TES headers, empty cat, SLP 3" stainless steel cat back, stock ECM & chip. Borg/Warner T-5 World Class, 12" Corvette rotors and clipers, GTA 16" wheels, South Side Machine subframe connectors, 1LE sway bars, 3.45 ring and pinion, Alpine sound.
Best E.T. 13.532
Best MPH 102.24
Old Nov 26, 2000 | 03:13 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
go to www.x-ram.com . they make an aftermarket intake manifold for Cross-Fire . ive heard that you will lose ALOT of low end torque but you will gain upper-end power. someone said that before they put it on they could smoke their tires. and after they couldnt chirp them. the best thing i think you should do is get your intake manifold bored. hope this helps
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
Eldebrock Headers, 3" Hooker Cat-Back, duel outlet with quad tips.
Mods: 1.6 Proform Roller Rockers, electric fan.
Future mods: X-Ram( Aftermarket Cross-Fire Injection Manifold that proves to have as much power as TPI www.x-ram.com )
Cross-Fire Injection after market chip that says that it will proform like 90's injections.. http://www.turbocity.com/CorvetteCro...ECMUpgrade.htm
Cleotiz
Jan 6, 2018 08:56 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 6, 2015 09:03 AM
