5.7 or 6 inch rods?
Old Oct 1, 2003 | 09:14 PM
pskel350's Avatar
5.7 or 6 inch rods?
whats the difference other then the length? does one have the ability to make more power?
which would be better for a 383 street engine?....i want to be able to hit low 12's.
Old Oct 1, 2003 | 09:28 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
As a rule, always use the longest rod whenever possible/feasible. If you're going to put new pistons and rods in no matter what, definately go with the 6" rods. Less piston to cylinder side loading, and it also slows piston velocity at mid-stroke, both of which will free up a little extra power and increase your high rpm reliability.
Old Oct 1, 2003 | 09:46 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
No it doesn't.
Using a longer dwell time at TDC and BDC (which is what happens) gives less time for the piston to move up and down the cylinder.
Just as an example with no merit to precise times....
Let's say you have a piston that uses 5.7" rods. At 6000 RPM the piston has to move up then back down the cylinder 100 times in one second.
Let's say that .2 seconds of that time is used for dwell at TDC and BDC combined. That leaves .8 seconds for the piston to make it's full travel up then down the cylinder 100 times.
You change to 6" rods and increase the dwell time to .25 seconds at TDC and BDC combined. You've just decreased the amount of time the piston has to move up then down the cylinder 100 times to .75 seconds.
It has to travel the same distance in less time. That means it has to move faster.
Again, these are just examples of the actual times, but that's irrelevant at this point.
Old Oct 1, 2003 | 10:26 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Another difference is since the rod is longer the piston has to have the pin mount moved up on it. That's why they sell pistons for 6.0 and others for 5.7... the ones with the 6.0 take a ring that keeps the oil ring from coming in contact with the wrist pin.
Old Oct 1, 2003 | 10:34 PM
OMINOUS_87's Avatar
Either or will be fine, this is something people really tend to get wrapped around the axle for and argue about, dont ask me why. The difference for a low 12 sec application on 5.7" Vs 6" isnt even worth talking about. Get whatever gives you the best deal on the greenbacks.
I am running 5.7"ers in my 383.
EvilCartman's Avatar
Car: '82 Z28
Here's a pic of one of my Wiseco pistons made for a 6 inch rod. Wrist pin comes really close to being into that groove.
Old Oct 1, 2003 | 10:37 PM
Engine: 383 SBC
I'm going to run 5.7's in my 383 also... balanced 4340 forged bottom with stud girdles and roller solid cam :-)
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
A little more infor on 6" rods
ok first look at this chart
http://www.iskycams.com/ART/techinfo/ncrank1.pdf
what youll notice is the longer rod stays closer to TDC longer, youll notice also that cylinder pressure peaks and starts dropping rapidly after about 24 degrees past TDC.
the piston has moved less than 1/4" from TDC at that point
http://www.chevytalk.org/forums/Foru...ML/009055.html
then read these CAREFULLY
http://www.aros.net/~rbuck/rick/rodstudy.htm
http://www.grapeaperacing.com/GrapeA...rodslength.cfm
http://www.stahlheaders.com/Lit_Rod%20Length.htm
http://victorylibrary.com/mopar/rod-tech-c.htm
http://victorylibrary.com/mopar/cam-tech.htm
http://victorylibrary.com/tech/crod-c.htm
http://victorylibrary.com/mopar/cam-tech-c.htm
Old Oct 1, 2003 | 10:39 PM
Engine: 383 SBC
Not to take over the thread or anything... but how do you like that 3k ACT stall with the 700-r4? I'm upgrading to 3.73s and a new 383 I'm thinking I'm gonna go bigger... I have 2400 ACT now with the SS 700r4
Old Oct 1, 2003 | 10:40 PM
AJ_92RS's Avatar
I agree 100%. I wouldn't waste my time nor money unless they were the same price. The benifits aren't worth the money/hassel.
I was talking with a friend and he pointed out that "mid-stroke" to Mike may mean "between strokes", which is correct, just worded in a strange way.
Old Oct 1, 2003 | 11:05 PM
DTL504's Avatar
This A.C.T. Converter was recommended by Dana and its GREAT, driving normal she shift real smooth and dont have to rev her to get the car moving. I will give it 98% grade as excellent. What 2% missing I dont know! Talk to Dana he will do a free upgrade on them convertors if you had it less than a year.
DTL504
Old Oct 1, 2003 | 11:57 PM
Car: '82 Trans Am
Transmission: TH475
Thanx for the correction AJ. I was about ready to get my flame-thrower out.
I will also agree that the actual performance gains are minimal. But if you're putting new aftermarket pistons and rods in (regardless of length), I'd definately go with the longer ones (price should be the same).
Old Oct 2, 2003 | 12:36 AM
DTL504's Avatar
Do like Smokey Yunicks said and I quote:
Put the biggest rod that you can fit in the engine...
Old Oct 2, 2003 | 08:49 AM
Engine: 383 SBC
Thanks DTL sounds like your 3k runs a lot like my 2400 with 3.27 gears... just wanting to make sure it wasn't going to be a big change. I got mine from Dana also. So with my new cam and 3.73s it should be fairly good behavior once Dana matches the stall.
Old Oct 2, 2003 | 05:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A longer rod will help to decrease sidewall wear on the cylinders and will not be as stressful on the engine at high rpm.
These were the 2 major problems with the 400 small block. The rods were really short, which made for excessive sidewall wear on the bores and the were fairly easy to grenade at high rpm.
Old Oct 2, 2003 | 06:02 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
If you are buying a complete assembly, then go for the 6" rods, price is usually the same. If you are thinking about retaining your stock rods to save a few bucks, go ahead...
I run 6" rods in my 385 but I bought a rotating assembly through my machinist years ago and the price was just right...
Old Oct 2, 2003 | 09:31 PM
pskel350's Avatar
i will be buying a complete forged bottom end, the price is the same for 5.7 or 6.
Thanks for all the info. I have decided to go with the 6 inch rods
Old Oct 3, 2003 | 01:26 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm in the middle of buying a 406 ...hope you're prepared to lay out the $$$ for a forged bottom end, but for a 383 it may be cheaper....
Old Oct 3, 2003 | 01:34 PM
DTL504's Avatar
I wanted to spend $1000.00 on a good bottom end and this is what I got.
EAGLE H-Beam Rods CRS6000B3D $335.09
CLEVITE Main Bearing MS1038P $27.00
Rod Bearing 8-CB663P $27.00
SCAT 9000 Int Ball Crank 400-3750-6000 $222.50
WISECO Pro Tru Forged Pistons PT020H4 (0.040) $419.00
TOTAL Price Including Shipping = 1030.59
Ok I did go over the budget by $30.59, but I have forge pistons, forge rods and a int bal crank.
Old Oct 3, 2003 | 01:37 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The Scat 9000 crank is not forged, but it is a very good crank made out of some good steel.
Old Oct 3, 2003 | 01:50 PM
DTL504's Avatar
I did not say my crank is forge, but I have forge rods and Pistons. I belive for what I want to do with my engine (RPM) I would not need a forge crank. Crank is usually not the weak point in a SBC bottom end. Its the rods bolt that usually break and tear everything else apart. Thats my reason for not wanting a forge crank. Also the 400 dont need to wind as high as a 350 to get max output out of the engine...
Old Oct 4, 2003 | 12:06 AM
Confuzed1's Avatar
Car: 83Z28 HO
That's exactly what I've read about them. If you are running a combo that requires a high RPM's, you need to invest in splayed caps for the 2 bolt main blocks. I don't know anyone that has seen a crank break at the track....spun bearings? YES - thrown rod? - YES..... but no broken cranks...
Hotrodboba400
Dec 10, 2019 07:07 PM
aharvel50
Sep 21, 2015 07:31 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
