moving to high altitude
Old Nov 26, 2000 | 09:00 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I live in Florida and moving to Colorado, is there any changes need to be made to the computer or will it adjust to the different air/fuel mixture?
Old Nov 26, 2000 | 09:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I recently moved from a sea-level location to a higher altitude area. I found lowering my fuel pressure a bit helped the WOT performance since the air is a bit thinner. Other than that, there is nothing you have to do (if it is fuel injected).
You can consider disconnecting the battery to reset the ECM and have it relearn the higher elevation. I have done this, but because I was doing some electrical work on my car.
db057
Apr 28, 2019 07:45 AM
nova983
European Region
Nov 2, 2015 12:15 PM
corey8084
Sep 17, 2015 02:56 PM
Stroopwafel
Sep 11, 2015 06:38 AM
adelane
Sep 9, 2015 08:51 PM
