what is code 36?
what is code 36?
What is code 36? I tried to find where it talks about engine codes in the tech articles but couldn't find it. What is code 36? How do I fix it? Is it hard to fix?
Guest
Posts: n/a
They are on the driver side firewall. One of the relays there is for the fuel pump, the others are for the MAF. They are around $10 each. I think the fuel pump relay has a large tan wire and large orange wire going to it so you can tell the difference between them.
Chris,
If your car is a Firebird, it should look something like this:
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
How would the MAF power relay effect heating up the hot wire? I haven't replaced this relay because I thought it would have no effect..and wouldn't you have driveability problems with no power to the MAF? I'm sure it is obvious I don't exactly understand when this relay comes into play..thanks..
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Groove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.68, 60 ft. 2.17, 1/8th mile 9.4
-Best MPH 93.9
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
-Best MPH 93.9
No no and..uhh.no..Vader is the most helpful person alive, but that picture is not if you have our cars. On mine, that looks completely diferent..same idea I guess but the placement is not at all the same.
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
-Best MPH 93.9
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
-Best MPH 93.9
